i have a small autohotkey script that i use for backing up my joplin data. btw, i’m using jopinportable on a windows10 machine with nextcloud as my storage location. my script does daily backups and also moves a monthly backup to another saved location on my NAS. only issue i am running into is the export location doesn’t always stay where I want it. for a feature request, is there a way to add something to the options to define a default export location? or an ability to add something to the command line of joplinportable to define the export location?
edit: i was able to change my script to accept the full qualified path for the backup so i guess i don’t need this anymore. but might be a nice idea, just in case.
thanks
