uniq
1
I work with the desktop version, not the cli version of joplin.
- The operating system used:
Manjaro Arch Linux
Hello, I would like to apply the genius idea of this backup script:
There are two directories where my notes are stored:
(1) $HOME/.config/joplin
(2) $HOME/.config/joplin-desktop
All my notes are stored in (2).
(1) is just automatically created and is useless for me.
Here is the Problem which I could not solve or find online or in the "joplin help all" page:
The command:
joplin export --format raw $HOME/Desktop/jExport/
exports only (1), but I need (2).
I would like to run the script in the background.
So that (2) is being exported.
You should be able to do that with --profile.
Your command would end up looking something like:
joplin ---profile $HOME/.config/joplin-desktop export --format raw $HOME/Desktop/jExport/
To be clear, this is an undocumented and (I believe) still unsupported flag, but it seems to be fairly well known.
