iOS
Nextcloud
I use Joplin on iOS and Linux desktop, sync on Nextcloud with LAN (not over internet). I guess my issue comes from an aborted sync due to lost WLAN connection on my iPhone. I tried to export in JEX then delete the note that is causing the issue but it seems that it's suck in the sync process since the log still shows the text on this note.
I tried to fix it also with note history, unfortunately it's wasn't a success either.
Is there a way to remove this note from the sync and add re-create it again manually (I have a backup)?
Many thanks!
