Drag and drop text cursor
Joplin 3.1.20 (prod, win32)
ID client : 9e3a49348bd943b0a9df0eaa283a4836
Version de Synchro : 3
Version du profil : 47
Trousseau supporté : Oui
Révision : 8199362
Persistent Editor Layout: 2.2.0
Joplin Server
I updated the Desktop app from 3.0.15 to 3.1.20 and noticed that attachment drag and drop in the Markdown editor don't work properly.
In the 3.0.15 version, it was working fine: the text cursor in the Markdown editor followed my mouse cursor until I release the mouse button. The attachment was added successfully at the new text cursor location.
In the 3.1.20 version, the text cursor in the markdown editor doesn't follow my mouse cursor. When I release the mouse button, the attachment is added successfully but at the last text cursor location before using drag and drop.
I think it is related to the new markdown editor since when I activate the legacy Markdown editor in 3.1.20 (Option, General, Advanced), the behaviour is identical to 3.0.15.
Is this a bug and can it be solved?
Thank you
Thank you for reporting this!
I've opened a pull request that should fix this issue!
Thanks a lot, it works with the new 3.1.22 desktop app!
