I am on latest 1.0.207 on Win10 and when I drop an image, Joplin goes completely white, except for the menu-bar (which still works), When I close Joplin and open again, the image was not included in the mark-down of the note. I have cleared my userstyles and userchrome completely empty with same result.
The image is a png of 1,62kB, which would be completely normal. I tried with jpg format – same thing.
I tried to revert to old release, but that will not start-up anymore, telling me i probably use an old release…
In the old editor, so no WYSIWIG. I have restarted the computer and white screen issue seems to be solved. But the image does not drop on the cursor location, but top of the note as the very first characters in the markdown. I am relieved, there is a workaround now, but a little annoying…
The whole source editor is a bit buggy, the screen keeps jumping to end-of-note during editing, after I attach file an image. I need constantly to scroll up to get back to my cursor where I am editing.
"pre-release rewrite": I can understand that there are some wrinkles than. In the end it will be an improvement no doubt. For a user it is a little confusing that not the expected results appear, could be simple issue or very difficult to chase issue. I will be patient
