Cursor position is often reset
Joplin 2.13.15 (prod, win32)
Client ID: 57a16bb4b4264794a45f14f6ab81d9aa
Profile Version: 44
Revision: 7d2c1c0
Admonition markdown extension: 1.1.0
Cursor Sync: 2.1.0
Draw.io: 2.2.0
Emoji: 1.0.4
Note Tabs: 1.4.0
Outline: 1.5.13
PlantUML2: 1.11.0
Quick Links: 1.3.1
Rich Markdown: 0.13.4
WebDAV
I'm using split view to edit markdown codes.
While I am editing texts, sometimes cursor jumps to the top of the document suddenly.
So my document being typed is often messed up.
I have not figured out the condition under which this happens yet.
Is there anybody who have experienced symptom like this ?
This is a known bug that happens when sync starts. See this Github issue: Cursor jumps to top of editor when typing · Issue #8960 · laurent22/joplin · GitHub
Thank you, I got it.
Can I disconnect the sync. In order to avoid the bug?
For the accent bug, it is easy:
  1. Create a text type H1 with accent like : Sólo
  2. Create a link to this label.
  3. Althoug the first time works ( sometimes either ) the next doesn't redirect to the linked text because it has accent. With the text H1 "Solo" it works.
