Version 1.01.169 for Windows
I’ve been using Joplin with Dropbox for a few months and have been very happy. Tonight a strange thing seems to be happening. Joplin Sync began deleting remote items. It is currently on item 564.
Grabbed this image on item 238. Now it has deleted 611 items. I did not intentionally delete anything. Is this just a monthly or quarterly or whatever database cleanup? or is something wiping out all my data?
I am not noticing anything missing so far and would imagine I’d notice something as it has now deleted 698 items.
Will it stop? What is happening?
Neither of the 2 android devices I’m synced with is turned on or running Joplin at the moment. This began after I’d been away from the computer for about 30 minutes.
I don’t have much time now to try and investigate. Ended up deleting about 1,100 items. I don’t see that anything is missing though. It is just scary to watch a critical program managing important data telling you it is deleting hundreds of items and not have any idea what is going on. I’m guessing that either Joplin or Dropbox was doing some data maintenance, but it would be nice if the message was less scary.
If you still have an unsynced app (on mobile for example), you can compare the synchronisation statuses and see what items were deleted on desktop. We could indeed provide more info about what gets deleted, not in the sidebar, because there’s no space, but at least in the log.
This happened to me just now. I set up a new computer, installed Joplin, and then told it to sync with my Dropbox. That worked fine.
Almost immediately afterwards, it began doing the "Deleted remote items: X" for a long time, first hundreds, then thousands, which was worrying. However, no notes were lost.
I think I know why it happened. It seems that most notes now have no revision history. It deleted all the old revisions.
For me I don't mind this - I don't need to keep around copies of every time I changed a note, which takes up space. It appears that all notes older than 3 months have had their revisions deleted.
When I go to settings in Joplin, it has a setting "Keep note history for (90 days)" which I have checked. I assume that on my old computer I had it set to a higher value, so that explains why it suddenly deleted so much after setting it up on this computer.
So, here on Feb 16, 2025 my Joplin notes didn't sync this morning due a 502 bad gateway with joplincloud.com;
So I changed my sync target to DropBox from joplincloud on my phone and started the sync to the new target;
The first thing it started to sync was the cryptic "Deleted remote items" and got up to 8859 items! then it started syncing "Created remote items";
I remember this extended sync process back when I started using my new phone a few months ago;
So my conclusion is that we (at least me) were misinterpreting what the sync dialog was indicating: it isn't saying it is "Deleting" items, it is saying it is "Syncing" deleted items;
So apparently there is nothing to fear;
I wish the sync process was faster;
I also wish I hadn't had to switch from joplincloud, but the reason I use the app is to have access to my data and be able to sync reliably! I used to use Evernote and when it started letting me down I found Joplin; I wish Joplin had some features that Evernote had, such as drag and drop in checklists; and now since Bending Spoons took over the search functions in Evernote are ridiculously unhelpful and almost unusable; so much for "New and Improved"; sometimes a product is just fine the way it is, and adding new features that nobody wanted and never implementing features that people have asked for for years is just crazy! Just my opinion; so now I still pay for Evernote because I have tons of notes in there that I haven't gotten around to moving yet, I pay for JoplinCloud to help the devs, and now I'm using DropBox for my sync target because JoplinCloud had a 502 bad gateway
Not saying that I know what I am talking about, but I also had the same fear. Eventually, though I found an "top bar > help > export deletion log" option in joplin, and there majority of the entries were Revision.deleteOldRevisions so I assume it is the revisions. Although, I have no idea why it is deleting revisions, since I am pretty sure I was not changing for a LONG time, and even when I did change something it was not something massive.
Just want to chime in to say I’ve also encountered this issue in the following scenario:
Have a main Joplin installation with thousands of notes and revisions, with revision history set to 10000 (i.e. a very large number to try to get it to not delete any revisions).
Set up a new Joplin installation on a separate laptop, start syncing, forget to change the revision history setting from the default 90 days.
Joplin starts deleting nearly all my note history.
IMHO this is not just a UI issue, but a quite serious data integrity issue. Some users care a lot about their note history, largely for the same reasons we care about revision history in a git repo. I will now have to recover mine from backups.
Can we not have an option to keep all revisions, ideally on by default?
Tweaking the sync message in the UI is only going to be a mild comfort to users. What they are thinking is: “why is Joplin deleting any of my stuff? I never asked for this.”
That’s a fair point, although I think a limited history retention policy which you opt into by default is pretty standard across software. The fact you can’t backup note history in a jex export does not help though.
There was a ticket created to make the note history ttl get synced with the sync target, so it will be the same for all clients, but it has been in the backlog for a long time. And also I’m not sure how it would know which client would be considered as the initial source of truth for the value.
The note history feature has not received much attention to be honest. My very first code contribution to Joplin was to make the note history ttl value settable with a text input on mobile, because for years before I started using Joplin, it previously used a tiny slider which made it impossible to set an accurate value unless you set the min / max / default value. So you couldn’t really match the value you set on the desktop client. I also fixed a couple of other longstanding issues with note history which I found along the way
Keep remote revisions for the longest setting amongst all clients, sync and keep local for corresponding local setting. Though it will need to know all sync clients and their settings.
@LightTemplar The feature has now been implemented. It initially leaves the local ttl value as is, but as soon as you make a change to the setting in the ui, that new value then overrides the value on all clients when synced
My thought was about my case, that there is a PC client and a mobile client - PC has more resources and can keep and handle more, than mobile. For urgent things I use mobile client, for any others - PC. Therefore, I think, having different TTL values for different clients is good.
That isn't going to work well, because whenever you open the client with a lower note history ttl value, it will remove expired revision for that limit on all devices
Therefore all clients will need to know about TTL of other clients. This was what I meant in "it will need to know all sync clients and their settings.". Clients will need to get their IDs and so on. If this isn't the case already, then I doubt this added level of complexity will worse it, but if it's already in the architecture, then why not to use it?
I don't see how what you're proposing is going to work to be honest. The note history is synced across all devices and therefore shares the same history, it's not separate history per devices. Therefore for the ttl to work well, you need to use the same ttl value on all devices, which is what the latest Joplin release now does (only taking affect when you change the ttl value for the first time since upgrading)
