Default Spacing Between Paragraphs
Joplin 3.3.12 (prod, win32)
Device: win32, 11th Gen Intel(R) Core(TM) i7-11700 @ 2.50GHz
Client ID: 63a86730a53e4574a7a0b3037f7da932
Alternative instance ID: -
Revision: 4d790b6
Backup: 1.4.3
Freehand Drawing: 3.0.1
OneDrive
When using the WYSIWYG editor (which I use more than the markdown) when I press Enter for a new line, it also adds a blank line. This creates way too much white space for me. Is there a way to change the default paragraph spacing? I would prefer that pressing Enter just bring me to the next line. If I want a blank line, I'll press Enter again. Thanks.
I can't agree more...
Long old story (have a look in the forum using the search)...
For example, read this:
"The newline error in the Joplin code - #9 by james-carroll"
A lot of us would like an option for that...
At this moment if you want to have only one line (and not two) press "[SHIFT] [ENTER]" instead of [ENTER] only.
WYSIWYG editor = RTE = Rich Text Editor
