Removing line spacing with "Enter" instead of "shift+enter"
Hello, how can I set Joplin to start a new line without interline spacing (just single line break) just by pressing "Enter" instead of "shift+enter"?
Joplin Cloud
Rich Text Editor
Common question. I don't think there is an answer that you will be 100% satisfied with. There is a way of adjusting the line spacing so not as much space. Between lines shows.
Here are some instructions you can follow that might help.
