CTRL+ALT+I stopped working for a while
Joplin 3.3.13 (prod, win32)
Device: win32, AMD Ryzen 7 5800H with Radeon Graphics
Client ID: b4223f63eed946bcb2bd594f6c77c80b
Alternative instance ID: -
Revision: 144ed59
AlertsPerfect: 1.0.1
Backup: 1.4.3
Cursor Sync: 2.1.0
Embed Search: 2.0.0
Freehand Drawing: 3.0.1
Hotstrings & Hotkeys: 1.0.0
Inline tags: 1.3.0
Markdown Table: Sortable: 1.2.2
Math Mode: 0.8.0
Note Variables: 2.0.0
Pseudocode Support: 0.1.0
Quick Links: 1.3.2
Recipe Scaler: 0.9.2
Search & Replace: 2.2.0
Templates: 2.4.0
Text Colorize: 1.2.5
OneDrive
I have several templates defined with the #template tag set. But, today, when I press CTRL+ALT+I... nothing happens. If I go to Tools > Templates > Insert Templates... nothing happens. The template notes do exist and are tagged. I shut down Joplin and made sure all tasks ended then restarted with no change. The Templates plugin is installed and active.
I did notice the Math Mode plugin had an update pending. When I updated it and restarted CTRL+ALT+I began working again.
Any ideas what might be going on?
I notice you've got my Hotstrings & Hotkeys plugin installed - any chance you assigned a hotkey to Ctrl+Alt+I in it as well? Even temporarily?
In my own testing doing so doesn't seem to matter or disrupt the Template plugin - just asking out of caution.
I didn't. I have a few hotstrings so I can quickly type acute characters but no hotkeys.
