Thanks, 1.4.5 works great.
Yes, have been using Evernote daily for many years, so I am quite familiar with it.
oh
I was using simple notepad on my phone.
I think i had free account on evernote but didn't use it.
Anyway, Joplin is best.
@ambrt , would you consider changing the plugin's icon? The current "star" is misleading as it's (almost universally) used an icon for Favourites.
I often smack myself in the forehead after absent-mindedly selecting the star icon and being reminded that instead of "favouriting" a note, I've inadvertently tried to make a new one.
**Agreed.
Perhaps a hand and finger pointing to the right, complementing the icon for backlinks, since this plugin does kind of go in the other direction from what backlinks plugin does.
Oh, true
There's a little bit limited choice - icons are provided by Joplin itself from this site Font Awesome
I'm worried that right hand pointing (as suggested by @jb261 ) together with left hand might be confusing.
How about this one:
I'm opened to any suggestion
What about the clone icon? There is software I use that has this icon for similar functionality
How about this one:
I think that it effectively conveys an action leading to a result
With regards to the other two suggestions:
I'm fully on board with @heviiguy's points here.
The clone icon is very frequently used to represent copying - that would be even more confusing for this plugin than the current icon.
Of the various icons, suggested, I like the right arrow into a new page.
Agreed!
I agree too.
It will be in next update.
New version with updated icon is uploaded
Thanks a great deal for this plugin - I've been waiting for this feature since I started using Joplin about a year ago.
A few issues I'm experiencing (Joplin 1.7.11):
New icon is good, btw.
I think that this is happening:
1.You highlight some text
2.Pop up asks you for title with that text prepopulated
3.You press enter (or click Ok)
In this case, text you highlighted is actually both the title and a body of the note and as such it is on top of a newly created note (with plugin setting ticked on).
There is quick fix for this in new version.
Thanks for the dialog box fixes
Couple more issues (with updated version, and possibly earlier but I didn't test):
Ok new version should have that fixed.
The thing is that it will still insert link to new note into active note's body.
Is this behavior you're looking for?
Do you mean undo of creation new note?
If so, i don't think its possible now via plugin.
When new note is created it has to be deleted manually.
Thanks ![]()
Yes, that's right - if I just wanted a new note without a link at my current cursor location, I could just use ctrl+n.
Ideally, yes, but also everything else - creation of the link to it, deletion of any text that was highlighted (and therefore copied into the new note).
Hi
This looks very useful. Good work. It looks like a clever alternative to highlighting text. It builds a separate library of highlights which I think is a more useful approach - a bit like the way that your typical ereader makes a new separate file of highlighted text, a feature I also find very useful.
My use case is that I mostly read notes I have added and then select useful content to include or summarise in later writeups (i.e. essays, blog posts etc.). A drawback to standard colour highlighting of text is that one still has to go back through the post to manually select and copy the highlighted passages. If asked to choose I can live without an actual coloured highlight if I can extract the text jsut as your plugin does.
However, I would like to make a suggestion, hopefully an improvement. After I have done several such extracts from different notes it is difficult at a glance to see which note the extracts have come from without opening them. Would it be possible to create a new subnotebook for extracts using the post title as a label (but also user editable) and putting all subsequent extracts from the same post into the same subnotebook?
For my use case that would probably greatly improve the organisation of extracts from multiple notes and make them more retrievable.
Hey, thanks for the great plugin. I have a feature request. Could there be an autodetect to make a new note a todo if the first line starts with - [ ]?
I (and from reading the thread, I know others do, too) use this a lot to organize my daily tasks using checklists. Often a task deserves its own note/todo and changing from note todo is a little disrupting in the workflow. I know about setting the default as todo (which is great) but there are other reasons I don't want to always enable that. Maybe it's not too big of an issue.
Does the "Don't insert title at the top of body (first line of text)" checkbox under Options -> Convert to New Note work?
I have checked it, but the title is always also prepended to note body.
