Code block imports from Evernote
Hi -- I am importing notes from Evernote and my code blocks are showing up like this:
[[BLOCK_OPEN]]jq -r '.[]|[.index, .name, .section, .award, .industry]|join("\t")' raw.json |pbcopy
[[BLOCK_CLOSE]]
I'm using version 1.4.19 (prod, darwin) on MacOS Mojave. The import worked amazingly well otherwise, and I was really hoping Joplin was the answer to my EverWoes. thanks!
UPDATE: Here's the raw content from the ENEX file:
<pre style="font-family: 'Source Code Pro',Consolas,monospace; white-space: pre-wrap; display: block; font-size: .9em; word-wrap: break-word; color: #333; background-color: rgba(102,128,153,0.05); text-align: start; padding: 0; margin: 0 0 1.1em; line-height: 1.6; border: 0; border-radius: 5px; word-break: break-all;">
<code style="font-family: 'Source Code Pro',Consolas,monospace; font-size: inherit; background-color: transparent; white-space: pre-wrap; border-radius: 0; color: #333; display: block; overflow-x: auto; background: #f8f8f8; padding: 1.3em 2em;">
  <div style="min-height: 1.5em; color: inherit; line-height: 1.6; background-color: transparent;">jq -r
  <span style="display: inline; line-height: 1.6; color: #d14; background-color: transparent;">'.[]|[.index, .name, .section, .award, .industry]|join("\t")'</span> raw.json |pbcopy
  </div>
</code>
</pre>
Could you provide the ENEX file? And are you trying to import as Markdown or as HTML?
Trying to import as Markdown. The ENEX is huge and contains some sensitive data -- I excerpted the problem text above, and attached is a scrubbed version of one note with the problem.
export-problem.enex (10.8 KB)
It works properly if I import as HTML, but that would mean the notes would no longer be (easily) editable, so I hope I can avoid that. What's interesting is that the rendered HTML has what looks to me like extraneous elements in the hierarchy:
<pre STYLE="font-family: 'Source Code Pro',Consolas,monospace; white-space: pre-wrap; display: block; font-size: .9em; word-wrap: break-word; color: #333; background-color: rgba(102,128,153,0.05); text-align: start; padding: 0; margin: 0 0 1.1em; line-height: 1.6; border: 0; border-radius: 5px; word-break: break-all;">
<code STYLE="font-family: 'Source Code Pro',Consolas,monospace; font-size: inherit; background-color: transparent; white-space: pre-wrap; border-radius: 0; color: #333; display: block; overflow-x: auto; background: #f8f8f8; padding: 1.3em 2em;">
<div STYLE="min-height: 1.5em; color: inherit; line-height: 1.6; background-color: transparent;">jq -r <span STYLE="display: inline; line-height: 1.6; color: #d14; background-color: transparent;">
Could it be the pre > code > div structure that's causing the problem?
That will be fixed in the next release.
