Closing of modal when clicked outside of it
Upon opening note properties modal or “Goto anything” modal there should be a feature of the modal closing when user clicks outside modal.I think this increases user flexibility.
Especially in “Goto anything” I felt it was needed since no cancel option is shown when no notes/tags is found and user has to go for ESCAPE .
That would be a great addition to the feature. Yes, clicking outside should close the modal as it can be closed only on pressing Esc key. I’ll try adding that real quick.
I don’t think we need this. Sublime Text has no close button either. How about vscode?
True @laurent But it’s not actually about need I just said we can have it as an additional feature for improving user flexibility.
Cool @coderrsid :+1: But if you willn't be working then I'll be working on it.
It’s just a simple addition and would work like a utility for mouse actions and also in VScode when we click outside the dropdown after pressing Cmd+P . It closes the dropdown modal.
Screen-Recording-2020-03-30-at-1
I guess this will work?
Screen-Recording-2020-03-30-at-1 (1)
Yes that would make sense, feel free to create a PR for it.
Sure. I’ll just do it right away.
If someone is up for this, i think that all modals should have this feature.
As of 1.3.18,"Add Tags", "Note properties" and "Statistics" modals don't work this way.
