Bible Reference/Citations
Looking for a plugin that will popup the bible text/verse from a Bible reference.
Example:
Reference = Genesis 1:1
Popup Text = In the beginning God created the heavens and the earth.
Looking for any tools or tips that can help with Bible study.
Thanks.
There are existing applications for this. I think Joplin is a sub-optimal choice for the use-case you intend.
The closest Joplin has to what you describe is the plugin “Enable abbreviation syntax”.
In a note you define an abbreviation in the format:
*[KEYWORD]: Meaning of the KEYWORD.
Then wherever the KEYWORD appears in the note text it is shown with a dotted underline and if the mouse is hovered over it the Meaning of the KEYWORD is displayed.
This is a manual process and on a per note basis only so it may not be as flexible as you need.
The footnotes plugin might also be useful here, but it’s also manual and won’t be a popup.
