doctor
15 November 2021 00:34
1
I'd like to hover over a highlighted text and pop-up a box with some content (text, image and etc). How can I do that?
Typora (another markdown editor) have a resource that shows a pop-up for footnotes (by markdown resource). Is there any similar in Joplin?
ylc395
15 November 2021 06:51
2
Can you provide a screenshot of Typora? Maybe we can implement the feature as a plugin
There is an option that allows a text pop-up to be displayed if a keyword defined within the note is hovered over with the cursor.
Every time that keyword appears it will have a dotted underline and will trigger the pop-up if hovered over.
The markdown required takes the format:
*[trigger word]: pop-up text
The feature can be found in Joplin settings under Markdown > Enable abbreviation syntax (wysiwyg: no) .
By its name you can see that this feature is actually intended to allow abbreviations to be defined such as *[HTML]: Hypertext Markup Language, so it may be a bit limited.
system
Closed
14 January 2022 09:41
4
This topic was automatically closed 60 days after the last reply. New replies are no longer allowed.
