Android
S3
I imported 140 or so notes as Markdown from Evernote using enex files and successfully synchronized them to S3. I can see the objects in the S3 console.
I saved the AWS credentials in a password manager accessible on both my desktop, an iMac, and my phone, an Android, so I am using the same Access Key.
I can successfully configure the S3 Synchronization on my Android app and get "Success! Synchronisation configuration appears to be correct" when I click on "Check Synchronisation Configuration" (Misspellings in in app.). I even try prefixing my Access Key with a 'q' and the check fails. Remove the 'q' and it succeeds.
When I click "Synchronise", the arrows spin for a while and I get "Completed .... (72s) Last Error: InvalidAccessKeyId: The AWS Access Key Id you provided does not exist in our records". How was I able to check my synchronization? I copied and pasted the credentials.
aws-s3-invalidaccesskeyid-error-when-trying-to-synching-39787-log.log (10.6 KB)
