S3
Why would it be getting rejected on one PC and not on others using the same credentials?
I have a portable installation that I copied to a new PC. Nothing that I can see has changed, but it will not authenticate to S3. None of the credentials have changed, and my original PC, phone, etc. still sync using the credentials. I've tried deleting tmp and cache folders. Logs only show that the bucket failed. This should work right? There's nothing I need to add or remove when copying to a new system?
Log output:
2023-11-29 00:17:16: "Scheduling sync operation...", "0"
2023-11-29 00:17:16: "Preparing scheduled sync"
2023-11-29 00:17:16: "Starting scheduled sync"
2023-11-29 00:17:16: Synchronizer: "Sync: starting: Starting synchronisation to target 8... supportsAccurateTimestamp = false; supportsMultiPut = false [1701245836430]"
2023-11-29 00:17:16: Synchronizer: "Indexing resources..."
2023-11-29 00:17:16: "ResourceService::indexNoteResources: Start"
2023-11-29 00:17:16: "ResourceService::indexNoteResources: Completed"
2023-11-29 00:17:16: models/Folder: "updateFolderShareIds:", "{"shareUpdateCount":0,"unshareUpdateCount":0}"
2023-11-29 00:17:16: models/Folder: "updateNoteShareIds: notes to update:", "0"
2023-11-29 00:17:16: FileApi: "get info.json"
2023-11-29 00:17:16: Synchronizer: "Error: Do not have proper permissions to Bucket
Code: rejectedByTarget
at FileApiDriverAmazonS3.get (C:\Users\Frank\AppData\Local\Temp\2X485tIfue1Nx5SvzKiVE0dHCLw\resources\app.asar\node_modules@joplin\lib\file-api-driver-amazon-s3.js:278:12)
at process.processTicksAndRejections (node:internal/process/task_queues:95:5)"
2023-11-29 00:17:16: Synchronizer: "Sync: finished: Synchronisation finished [1701245836430]"
2023-11-29 00:17:16: Synchronizer: "Operations completed: "
2023-11-29 00:17:16: Synchronizer: "Total folders: 257"
2023-11-29 00:17:16: Synchronizer: "Total notes: 1739"
2023-11-29 00:17:16: Synchronizer: "Total resources: 808"
2023-11-29 00:17:16: Synchronizer: "There was some errors:"
2023-11-29 00:17:16: "Setting up recurrent sync with interval 600"
2023-11-29 00:17:16: "Sync has finished and note has never been changed - reloading it"
