Hello-
Joplin looks like an amazing piece of software! Thanks to Laurent and all involved.
I'm using version 1.14.11 on Android and 1.14.19 on Macos. I set up a File System sync that works from Android to Macos and not the other way around.
- I create a note on Android -> it shows up on Macos
- I modify the same note on Macos -> it's deleted from Android (and of course notes created on Macos don't show up on Android either).
I might be overlooking something but I couldn't find a post with the same issue and the timestamps of the notes seem correct.
Could you please help me figure this out?
