An easier way to see URL of a note?
Hi, I often end up with notes that have a URL attached (either via web clipper or manually), but I see no (obvious) way to see if a note has a URL.
Is it possible to somehow see if a note has a URL without clicking on the note properties icon?
@fstanis welcome to the forum.
I am not a dev just a user like yourself.
I see that this subject has come up before as there is no way of telling if there is a URL in the note properties without actually opening the note properties.
None of the above have resulted in any lengthy discussion and some also go further suggesting a clickable button is added to the interface. I must agree with you that a way of just knowing that there was a stored URL would be useful, even if it was just changing the note properties icon colour.
Ah, thank you! Really sorry, I should’ve searched for this more.
I think this’d be cool to add. Added a proposal here: Web clipper source URL - why hidden in note properties?
Thanks to @dpoulton for pulling that answer together.
Is there still no possibility of doing this? Perhaps now in a plugin?
