on Desktop I got the welcome screen with 3.6.16 -> 3.7.16 update suggestion. In Google Play the latest version available is 3.6.22. Wasn't there an incompatible change in storage format that makes it impossible to use mixed 3.6/3.7?
It has been fixed in mobile 3.6.22. You're good, no need to worry
App stores generally require review and other processes, so there may be slight timing discrepancies. If you want the latest version, you can download the APK file from https://github.com/laurent22/joplin-android/releases. The changelog can be found at https://discourse.joplinapp.org/t/android-pre-release-v3-7-is-now-available-updated-05-09-2026/50225?u=xiaofeng.
