Joplin 2.2.2 (prod, win32)
Client ID: b8990243001f4ae48c7e80600a1265bd
Sync Version: 2
Profile Version: 39
Keychain Supported: No
Revision: 37ad613
portable version running on 2 different Win10 systems (1 pro and 1 home)
file attached for reference
Bio Comp Testing.jex (176.5 KB)
when using the standard markdown editor and viewer, the attachment links work fine. when i use the WYSIWYG editor, when I click (ctrl-click) a note attachment I get the following error:
is this a limitation of the WYSIWYG editor or a bug? i just recently started trying this editor so I don't know if this is a new problem or one that has been there a while.
thanks
steve
