- The version you are using. LATEST VERSION is not a version number!
- If it is a sync issue, please let us know what you are syncing with.
- If you report a problem with upgrading, please let us know both versions (from/to).
- If you report a problem with the editor, please tell us which editor you are using (WYSIWYG/Markdown).
- The operating system you are using.
When I drag'n'drop an attachment (or attach via the button) I'm seeing a link such as  when I switch to Viewer mode. Old notes with attachments so far seem to still show the attachment. The problem is only happening for new attachments.
MacOS 11.2.1
Joplin 1.7.11
Using Markdown editor
