Won't decrypt after sync
I just installed Joplin on a laptop running Linux, and when I try to sync it decrypts only a small fraction of my notes. I have tried several times to delete the local data and re-download from the sync target, with the same result each time.
    Joplin 2.8.8 (prod, linux)
Client ID: 097fbb66050c40babae973c79205ccda
Profile Version: 41
Keychain Supported: No
Revision: c2a6a13
    Joplin Cloud
    Linux Mint 20 Cinnamon
If you can also please provide a log, as described here: How to enable debugging | Joplin
