I use Joplin to take some mathematical notes. It's a bit inconvenient when entering formulas: I need to first type two dollar signs, then a backslash, and then the LaTeX command.
Will Joplin have a snippets plugin similar to those in Vim and VSCode, allowing users to customize snippets for quick input?
Furthermore, is there a plugin that supports a way of entering mathematics similar to TeXmacs, where you can type some letters and quickly obtain the desired formula by pressing the Tab key repeatedly?
I'm linking to a snippets plugin that supports the Markdown editor:
thank you.I got it.
It use the note for the snippets config.I did not understand the readme.
and editor in the new version Joplin has already been code mirror 6.
