Why does Joplin open port 3000?
Running Joplin 2.9.17 on macOS.
I need an application to start listening on port 3000, but Joplin already has this port opened. So I have two questions:
  1. Why does Joplin need to open this port?
  2. How can I reconfigure it to use a different one?
thanks
P.J.
Joplin doesn't open port 3000. Maybe a plugin does something weird?
Thanks for the info, I'll investigate into this
You can also try disabling the web clipper (if enabled in settings).
Webclipper is a different port (above 40.000).
It's the cursor sync plugin (GitHub - ylc395/joplin-plugin-better-markdown-viewer: Keep Cursor Synced Between Editor and MD Viewer) that opens a websocket on 127.0.0.1:3000
I was just wondering as well and opened an issue for that.
