Hi
I have Windows 64-bit system on my laptop. How do I know what version of Joplin I have, if it is 32 bit or 64 bit system and is there a 64 bit system of Joplin?
Hi
The installer detects your OS automatically and installs the appropriate version, however if you don't know, then it's the 64-bit one for sure, simply because the 32-bit releases have been broken for a very long time (previously requiring a manual fix to show anything on screen, and nowadays even the fix doesn't work anymore).
Ok but when I click on the help meny in Joplin it stands prod, win32 into brackets.
Joplin 2.12.19 (prod, win32)
In this case, win32
refers to just Windows
(without specifying the bits). It would be something else on different operating systems. The About window itself doesn't seem to show whether the release is 32 or 64-bit.
