Many versions of Joplin on my PC?
Joplin 3.2.13 (prod, win32)
Client ID: e1e9926881014d1fa74d51180605b4f1
Revision: a898e17
Backup: 1.4.2
Freehand Drawing: 2.14.0
Dropbox
Hello! I'm using the program Revo Uninstaller and it found 3 versions of Joplin installed on my PC. Is that normal? Can I unisntall the older versions or will it create à bug? Thanks! :slight_smile:
If we look at the sizes, obviously your joplin data directories (strange but maybe one for each installation I suppose) are not empty... So backup them (and more) before taking any action !
C:\Users\YOUR USER NAME\AppData\Roaming\Joplin
ETC...
Au fait ami compatriote : vous avez mis le titre du topic en français... Les non francophones vont se sentir exclus... :wink:
Ευχαριστώ Στεφ! :grinning_face: Oui, j'étais confus parce que l'interface était en Français mais les boîtes de dialogues en anglais. Je vais le modifier. :folded_hands::dolphin:
Indeed !
