Android
WebDAV
Hello there. excuse for my ignorance but i have trouble with synchronize joplin with android
WebDAV Synchronization Issue with Leviia on Android
Context:
Synchronization works perfectly on my computer Linux Mint 22.1 x86_64
On my android phone, synchronization fails with an error (see screenshot)
I followe the same procedure as on my PC, using the WebDAV URL
The webdav provider is Leviia.
I tried setting the target as WebDAV and Nextcloud in Joplin Android, but the same error occurs.
I have regenerated the application password multiple times, with no success (from Leviia interface)
What I have checked so far:
The WebDAV URL and password is correct (confirmed with Leviia). (and i made 3 times the manipulation)
Synchronization works on my PC.
I asked to Leviia :
Leviia’s Response : Leviia support suggested that since synchronization works on my PC, the issue likely comes from Joplin Android and advised me to reach out to the Joplin developers.
If anyone can help me with this trouble
Additional information:
Smartphone is a Fairphone 5 with CalyxOS
Thank you in advance for you help ![]()
screenshot :
