Am I doing something wrong or did i find two unsupported symbols in KaTeX within the markdown-editor? I am specifically talking about \female and \male, which should be available if I'm not mistaking.
Just to be clear, I am not talking about the symbols in normal text but within chemical or mathematical equations.
Thanks for your help!
Joplin 2.3.5 (prod, darwin)
Client-ID: 78832704148c45b696618d967ffe03be
Sync-Version: 3
Profil-Version: 39
I've checked the katex docs and I can't find those symbols. Can you share the reference that you're using? If they are indeed katex symbols, it's possible that the Joplin version of katex needs to be updated.
you may be right - i was checking Detexify LaTeX symbol table (search for "female" or "male"). It says there that it's available in textmode & mathmode. But seems to be working only in LaTeX, not KaTeX.
