Unexpected token in JSON at position 4096
SyntaxError: Unexpected token in JSON at position 4096
at JSON.parse ()
at MigrationHandler. (C:\Users\xr057\AppData\Local\Programs\Joplin\resources\app.asar\node_modules@joplin\lib\services\synchronizer\MigrationHandler.js:50:31)
at Generator.next ()
at fulfilled (C:\Users\xr057\AppData\Local\Programs\Joplin\resources\app.asar\node_modules@joplin\lib\services\synchronizer\MigrationHandler.js:5:58)
@xr0573 welcome to the forum.
When you created this support post you deleted the template text that requested certain information was provided.
The circumstances under which you got the error would also be useful.
在 A 电脑上备份数据,然后在 B 电脑上使用相同的 Lattic 帐户登录并还原备份数据,这样可以实现数据同步吗?为什么不行?
软件版本 1.8.2
Google translate
Backing up the data on computer A, then logging in with the same Lattic account on computer B and restoring the backup data, will the data be synced? why not?
Software version 1.8.2
Well, can't say I didn't try. Good luck.
2023-04-29 20:11:28: joplin.plugins: "Starting plugin: com.github.marc0l92.joplin-plugin-github-theme"
2023-04-29 20:11:28: "DecryptionWorker: starting decryption..."
2023-04-29 20:11:28: joplin.plugins: "Finished running onStart handler: com.github.marc0l92.joplin-plugin-github-theme (Took 99ms)"
2023-04-29 20:11:28: "DecryptionWorker: completed decryption."
2023-04-29 20:11:28: "Preparing scheduled sync"
2023-04-29 20:11:28: "Starting scheduled sync"
2023-04-29 20:11:28: Synchronizer: "Sync: starting: Starting synchronisation to target 2... supportsAccurateTimestamp = false; supportsMultiPut = false [1682770288210]"
2023-04-29 20:11:28: Synchronizer: "Indexing resources..."
2023-04-29 20:11:28: "ResourceService::indexNoteResources: Start"
2023-04-29 20:11:28: "ResourceService::indexNoteResources: Completed"
2023-04-29 20:11:28: Synchronizer: "SyntaxError: Unexpected token in JSON at position 4096
at JSON.parse ()
at C:\Users\xr057\AppData\Local\Programs\Joplin\resources\app.asar\node_modules@joplin\lib\services\synchronizer\syncInfoUtils.js:59:27
at fulfilled (C:\Users\xr057\AppData\Local\Programs\Joplin\resources\app.asar\node_modules@joplin\lib\services\synchronizer\syncInfoUtils.js:5:58)"
2023-04-29 20:11:28: Synchronizer: "Sync: finished: Synchronisation finished [1682770288210]"
2023-04-29 20:11:28: Synchronizer: "Operations completed: "
2023-04-29 20:11:28: Synchronizer: "Total folders: 2"
2023-04-29 20:11:28: Synchronizer: "Total notes: 4"
2023-04-29 20:11:28: Synchronizer: "Total resources: 1"
2023-04-29 20:11:28: Synchronizer: "There was some errors:"
at JSON.parse ()
2023-04-29 20:11:28: "Sync has finished and note has never been changed - reloading it"
2023-04-29 20:11:28: "Updating all notifications..."
2023-04-29 20:11:28: "Garbage collecting alarms..."
2023-04-29 20:11:29: "DecryptionWorker: starting decryption..."
2023-04-29 20:11:29: "DecryptionWorker: completed decryption."
2023-04-29 20:11:31: RevisionService: "maintenance: Starting..."
2023-04-29 20:11:31: RevisionService: "maintenance: Service is enabled"
2023-04-29 20:11:31: RevisionService: "collectRevisions: Created revisions for 0 notes"
2023-04-29 20:11:31: RevisionService: "maintenance: Done in 106ms"
2023-04-29 20:11:37: "SearchEngine: Updating FTS table..."
2023-04-29 20:11:37: "SearchEngine: Updated FTS table in 2ms. Inserted: 0. Deleted: 0"
2023-04-29 20:11:57: "ResourceService::indexNoteResources: Start"
2023-04-29 20:11:57: "ResourceService::indexNoteResources: Completed"
2023-04-29 20:11:57: "ResourceService::deleteOrphanResources:", ""
