Undo of deletion not possible?
Version: Joplin 2.8.8 (prod, win32) Revision: c2a6a13
Windows 10
im trying to undo a deletion/cutting of a text, but its not working. Is this intended?
I can undo any typing i do, but i cant undo if something got deleted.
Please assist.
Ctrl+Z should work?
hmmm. the hotkey combo works indeed, but the option in menu does not.
is this problem known?
I just tried to undo a delete today using the menu item undo and it did not work for me either. I am happy to know a CTRL+Z will work.
Profile Version: 41
Revision: c2a6a13
I did a little more investigation on this. I found if I used the Delete (Back) key to delete individual characters the menu Edit/Undo would work.
If I highlighted a block of characters then used the Delete (Back) key to delete the highlighted characters as a block, Edit/Undo would not work but CTRL+Z would undo the block deletion.
Interesting behavior.
Profile Version: 41
Revision: c2a6a13
