Joplin 3.3.5 (prod, linux)
Device: linux, x64
Client ID: 09c50d7c0c71473d9c6dcbeff1c5f06d
Keychain Supported: No
Alternative instance ID: -
Revision: b3a3690
Record: 1.5.0
Rich Text Editor
Before a bug report to Github...
The problem is the same under Windows and Linux.
After deleting a note,
it's not possible to have it back immediately using the traditional [CTRL] [Z] undo.
However it is possible to undo the delete using the "cancel" on the popup during four seconds:
Do you think it's a bug ?
