Undo does not work to restore text cut with the keyboard shortcut
Joplin 3.2.13 (prod, linux)
Client ID: a5cea2926349473ab5b290a37725b32b
Keychain Supported: No
Revision: a898e17b4
Auto Tag: 1.0.3-rc7
Backup: 1.4.2
Freehand Drawing: 2.14.0
Outline: 1.5.13
Zotero Link: 1.1.1
As described before by someone else, Undo does not work to restore text cut with the keyboard shortcut.
Step to recreate:
  1. write text
  2. highlight the text and select Ctrl+X
  3. select undo or type anything and hit undo back to where you cut
    results: it will undo actions up to and past the Ctrl+x, but will not undo the cut. Ctrl+Z or using the Edit > Undo, neither works.
I could not reply there, so I am making a new topic
  • this problem applies to me as well
  • the Note history feature (Note > Note properties > Previous versions of this note) helped restore my text.
Have you try a newer version of Joplin ?
By my side (WINDOWS 11 or KUBUNTU 22/04 + Joplin 3.3.5) the undo works (menu and [CTRL] [Z])
BUT sometimes not immediatly ! I mean I have to do it 2 times before everything becomes like before. But it works.
Ah thanks, I'll take your word for it! Right, for reporting a bug I should have tried with a revision later than "stable". My main goal was to have a searchable instance of the fix.
You have the last screenshot above for it... LOL
I select, I cut, I CTRL Z.
Is it a "solution" to this topic ?
