I just tried to upgrade to Joplin 1.0.114 on Ubuntu 18.04 by using the recommenden method:
wget -O - https://raw.githubusercontent.com/laurent22/joplin/master/Joplin_install_and_update.sh | bash
Script said upgrade went fine, but after upgrade I can not find the Joplin launcher anymore…
Would be very grateful for any help on
Fixing the problem so Joplin appears in the launcher (so that I am able to start it).
Starting it from command line until #1 is solved.
Thanks for all help!
Egil
