Toolbar dissapeared
Joplin 3.1.20 (prod, win32)
Client ID: 85d67c64780649448fc0400a1a3da146
Revision: 8199362
Agenda: 3.7.1
Backup: 1.4.2
Code Section: 1.0.6
Code-Clipboard: 1.0.0
Combine notes: 1.2.2
Copy Code Blocks: 1.1.2
Create and go to tags and @notebooks: 1.3.7
Embed Search: 2.0.0
Enhanced Editing: 0.1.0
Event Calendar: 0.2.2
Inline TODO: 1.7.1
Reset Checkboxes: 1.0.3
Simple Highlighter: 1.0.0
Text Colorize: 1.2.5
All text and buttons from toolbar dissapeared, just gray field and date selector is inactive. I tried to reinstall the program, but have no luck
Please try to remove any custom CSS (if you've been using any). If that doesn't help, then you can try disabling the plugins one by one (or all at once, and then re-enable them individually) and see if there's any difference after doing so.
