The Latex formula has problem when change the system font size in Android Joplin
Android
Joplin 3.0.7 (prod, android)
WebDAV
The Latex formula has problem when change the system font size in Android Joplin. When I change the font size, the vector not display correctly. This is Chinese character. In the screenshots below you can see when the font is changed larger, the alphabet is larger but the vector signs position not change. It should higher. Are there any method to solve this problem? Thanks for any help!
