Small font on android
When I just want to read notes, the editor font size is not respected. If I click edit, then it is.
The reading mode font size is notably smaller than that of the rest of the system apps. I usually have to go to system settings and increase the whole system font size in 2 points just to use joplin.
Would it be possible that joplin respects that system setting, or that the editor font size is also used for non-editing mode?
