In Win10, when using the client software, the synchronization is completed when the attachment of a note (such as 1. txt) is modified on client A, but the attachment content on client B (synchronization completed) will not be synchronized and changed. I think this is a bug
For someone to try to work out what may be happening it could be useful to know:
- What version of the Windows desktop client you are using
- What sync method / service you are using
- What method you used to modify the attachment
The JOPLIN version under Win10 is 2.12.17
What sync method/service you are using
The method of synchronization is through the internal network's Qunhui webdav
The way to modify the txt attachment in the note is to hold down Ctrl to open the attachment, then modify the content in the open window. After making the changes, close the window, and if you open it again, it is indeed the modified content. After synchronization, when you open the attachment in another client, it is the original content!
