Synchronization problems
Joplin 10.7.2
Sync with https://mark.nl.tab.digital/ NextCloud server
I don't have any errors in synching a desktop version ( Joplin 1.8.1 (prod, darwin)), however iOS version shows many error messages. There is no Diagnostics & Usage under Privacy or anywhere in iOS 14.4.2 and Log screen in Joplin does not allow select/copy/paste. Here are a few screenshot (not all of them):
@bre
The sync feature seems to work flawlessly for many users. I cannot tell whether you gave sync enough time to complete ? Search for an earlier post of mine about how to get this fixed.
