Joplin desktop is syncing but not syncing
If you are not sure if it's a bug or not, PLEASE POST ON GITHUB ANYWAY.
Joplin 2.10.19 (prod, win32)
I'm syncing with nextcloud using WebDav, every time I open Joplin desktop, I can see the syncing icon turning with the word "cancel", but I can't see what is being synced like when it is actually syncing, when I click "cancel", it says "canceling" but it is not doing anything, what can I do in this situation, I'm also using Joplin on iPhone, and it syncs perfectly on my phone.
Windows 11 Pro N
If you can also please provide a log, as described here: How to enable debugging | Joplin
Are you using Onedrive cloud for your Joplin sync, bro😀?
No, I'm using Nextcloud from a third party provider...
this is the error message -
Completed: 10/06/2023 12:19 (505s)
Last error: FetchError: Response timeout while trying to fetch https://nc.nl.tab.digital/remote.php/dav/files/xxxxxx/Joplin/info.json (over 120000ms)
Yes, I have at same issue but I use onedrive third party provider as well.
Yesterday, on my Joplin desktop I couldn't sync. And now, today i use normally :smile:. What about you now, bro? :joy:
Still the same, maybe I should consider switching to one drive or dropbox...
