I have a similar issue to visumbra, though basically in reverse. Synchronisation from Android to Windows 10 per Syncthing works, but it doesn't the other way around.
I tested whether Syncthing can synchronize in both directions, and it can.
What I noticed is that Joplin displays the following error message every time I try to sync:"Error: Got metadata for path but could not fetch content: bd7e689960e0419bb9db8c644b23975e.md". I don't guarantee that I typed that filename correctly, but that was probably a pointless exercise anyway!
I'm at a loss now what I should do about this error, so some pointers in the right direction would be very appreciated!
Can you check your Syncthing dir for a file named bd7e689960e0419bb9db8c644b23975e.md
or whatever the id was? Is it present on both devices?
If I read the code correctly the error means that Joplin could see the file but was unable to read it.
Yes, the file is there and it’s not empty. Now Joplin gives me an error message regarding another MD file, which is identical to the prior one apart from the id, updated_time and user_updated_time data.
I stopped Syncthing from synchronizing the folder for the moment. Doesn’t help.
