i switched from Nextcloud to seafile and now i have the Problem, that Joplin on iPhone could not reach the Webdav Server. I am using the latest available Software on each Device
First i tried it with the Joplin Client for MacOS.
Url: http://xxx.xxx.xxx:8080/Apps/Joplin
User: myuser
Pass: mypass
That is working. The Client sync the Notes without any Error. I could also get Access to the Webdav Folder with an normal WebDav Client without Problems.
Only the Joplin Client on iPhone did not like it and told me that the Network Request failed and i should check it.
I checked it several times and i could not find any difference to the working Macbook
I tried also to reinstall the Client on the iPhone, but also no luck.
So my Question is, is there a known Problem? Seafile was reported to work.
Kai
