Sync Problem with NextCloud
The below suddenly appeared when I was syncing just now. However, it was still working fine 2 hours ago. Can someone explain what this is?
Sorry, I'm not a tech-savvy person, so I don't understand what it means or how to fix it. Can someone help me out here? Thank you.
Last error: Error: PUT locks/sync_desktop_fc055c5ceaa44f28b02d9e277bf5fb50.json: "Joplin/locks/sync_desktop_fc055c5ceaa44f28b02d9e277bf5fb50.json" is locked (Exception OCA\DAV\Connector\Sabre\Exception\FileLocked) (423): <?xml version="1.0" encoding="utf-8"?> <d:error xmlns:d="DAV:" xmlns:s="http://sabredav.org/ns"> <s:exception>OCA\DAV\Connector\Sabre\Exception\FileLocked</s:exception> <s:message>"Joplin/locks/sync_desktop_fc055c5ceaa44f28b02d9e277bf5fb50.json" is locked</s:message> </d:error>
Even without being technical you should consider searching the forum first. There's even a FAQ post specifically for this error because everyone comes here to ask about it, even though it's not a Joplin but Nextcloud bug:
https://discourse.joplinapp.org/search?q=FileLocked
