Joplin 2.8.8 (prod, darwin)
Client-ID: a764fc3d108746388ff762e35df54f97
Sync version: 3
Profile version: 41
Supported keychain: Yes
Revision: c2a6a13
I have a sync problem between my MacBookAir (macOS Monterey 12.3.1) and my iPhone7 (iOS 15.0.2).
The error message is: Error: Cannot acquire exclusive lock becaust the following clients have a sync lock on the target.
During setup and shortly after everything went fine and since yesterday this error comes.
What sync target are you using? On NextCloud/WebDAV it sounds like a file has got locked, it should expire eventually, it isn't a Joplin issue as such. This is frequently an problem for people using free tiers of NextCloud/WebDAV providers.
Yes, I use a cloud provider with webdav. How can I find out which file is locked?
It should be in the log file - instructions to provide it were in the template when you create the post:
system
Closed
4 August 2022 10:19
5
