macOS
Joplin 2.13.15 (prod, darwin)
Client ID: 33dd70c4b2ea44b8815519a528e4431b
Profile Version: 44
Keychain Supported: No
Revision: 7d2c1c0
macOS theme: 1.3.18
Outline: 1.5.13
Dropbox
Hello Joplin Community,
I hope this message finds you well. I am currently experiencing synchronization issues between my old MacBook Pro and the new MacBook Pro with Joplin, and I'm seeking assistance to resolve the issue.
On my old MacBook Pro, I moved multiple notes into folders, and since then, the notes are not syncing to the new MacBook Pro. I attempted to resolve this by executing "Delete local data and re-download from sync target" on the new MacBook Pro, but the synchronization did not occur.
To troubleshoot, I performed "re-upload local data to sync target" on the old MacBook Pro, which took approximately 41 hours to complete.
Additionally, on the new MacBook Pro, I deleted the
~/.config/joplin-desktop/folder and initiated synchronization again, but the notes did not appear.
Could you please provide guidance on how I can successfully synchronize the notes between the two MacBook Pros?
Thank you for your assistance.
Best regards,
motohasi
Syncronization Status on my OLD MacBook Pro:
Not downloaded: 0
Downloading: 0
Downloaded and decrypted: 16390
Downloaded and encrypted: 0
Created locally: 35725
Error: 0
Sync status (synced items / total items)
Note: 19834/19834
Folder: 25/25
Resource: 52115/52115
Tag: 1/1
NoteTag: 14/14
Revision: 4201/4200
Total: 76190/76189
Conflicted: 0
To delete: 0
Syncronization Status on my NEW MacBook Pro:
Not downloaded: 0
Downloading: 0
Downloaded and decrypted: 0
Created locally: 3
Error: 0
Note: 5/5
Folder: 1/1
Resource: 3/3
Tag: 0/0
NoteTag: 10/10
Revision: 9084/0
Total: 9103/19
Conflicted: 0
To delete: 0
