Initial Syncing Problem with Joplin Server
macOS
Joplin 3.0.15 (prod, darwin)
Client ID: aaa4d766c4c1420699bb4ebff244cba3
Revision: 598677b
Backup: 1.4.1
Joplin Server
I've got a Mac Client and an iOS client syncing with Joplin server, but I'm not having success adding a second Mac client. Notes do seem to sync between the clients but notes that were on the server prior to when I set up this client don't seem to ever make it here.
I've tried "Delete local data and re-download from sync target" but it doesn't help. Any other tips besides from remaking every note as a new note?
Attached is a screenshot of the sync status from the new client and some output from logs.txt.
The one warning I see in the console in debug mode is "Trying to reload note that has been deleted: null"
Log file
synclog.txt (3.02 KB)
I was just trying to duplicate some of my old notes to see if they would start syncing. Duplicating a note in a notebook that wasn't syncing didn't work so I tried to make a new notebook. My first step was to edit the notebook to add "-old" to the name so I could make a new one with the old name.
It let me rename the notebook and then it disappeared taking all the notes with it.
What is the recommended way to sync if Joplin Server is like this?
