SYNC Issue (WebDAV)
Using Joplin (V-2.10.8) on Android and Windows (V-2.9.17 Portable).
Syncing to a hosted WedDAV server (E2E enabled)
As of this morning SYNC has an issue. Getting the following error msg on Windows
Completed: 03/27/2023 09:10 (117s)
Last error: Error: DELETE locks/1_1_e0bbffb3a7c7433d8b61bb7d9dc01a2e.json: Unknown error 2 (400):
And on Android:
Completed: 27/03/2023 08:59 (45s)
Last Error: Error: DELETE locks/2_2_290baed780bd4e3e92175a94f2a16003.json: Unknown error 2 (400):
Looking at the filesystem on the WebDAV server. in the directory name 'locks':
I do have a file named: 2_2_290baed780bd4e3e92175a94f2a16003.json (Android error msg)
I do not have a file: 1_1_e0bbffb3a7c7433d8b61bb7d9dc01a2e.json (Window error msg)
What is the best course of action to solve my sync problem?
Tnx in advance
Did some more digging and it turns out the issue appeared on 03/24 for the first time... just did not realize it.
I copied part of the LOG file to get some more insights from an expert on this forum: https://web.tresorit.com/l/DLwLO#JWovdBd3nEVAs9qoodnlEQ
It seems WebDAV related... a snipped from above LOF file extract:
2023-03-24 16:07:45: Synchronizer: "Error: DELETE locks/1_1_e0bbffb3a7c7433d8b61bb7d9dc01a2e.json: Unknown error 2 (400):   2d
Code: 400
    at newError (C:\Users\mash\AppData\Local\Temp\2HZj4IZBHeRUj6rf0zpEM8QxyJ5\resources\app.asar\node_modules\@joplin\lib\WebDavApi.js:414:11)
    at WebDavApi.exec (C:\Users\mash\AppData\Local\Temp\2HZj4IZBHeRUj6rf0zpEM8QxyJ5\resources\app.asar\node_modules\@joplin\lib\WebDavApi.js:444:10)
    at process.processTicksAndRejections (node:internal/process/task_queues:96:5)
    at async FileApiDriverWebDav.delete (C:\Users\mash\AppData\Local\Temp\2HZj4IZBHeRUj6rf0zpEM8QxyJ5\resources\app.asar\node_modules\@joplin\lib\file-api-driver-webdav.js:206:4)"
Any ideas?
