Sync differences between PCs & Smartphone, using WebDAV kDrive
Description: Sync differences between PCs & Smartphone, using WebDAV kDrive
Version: 1.0.179 (prod, win32)
OS: Windows 10/Windows 10/Android 9
Details:
I’m currently encountering big synchronization problems between my 3 devices with Joplin: 2 PCs under Windows and 1 phone under Android.
Notes on one side don’t reflect properly on the other, when I move a notebook, it is not moved elsewhere, etc…
I use the new cloud service kDrive, which is based on webdav, so it’s fully compatible with Joplin. I’m trying to reset each instance, and it’s starting to become a problem since some notes have become incomplete over time.
Has there ever been this kind of problem before? Is it due to webdav?
Status de la synchronisation (objets synchro. / total) (PC Windows)
Note: 157/157
Folder: 46/46
Resource: 500/500
Tag: 0/0
NoteTag: 0/0
MasterKey: 0/0
Revision: 114/114
Total : 817/817
Conflits : 4
A supprimer : 0
Status de la synchronisation (objets synchro. / total) (Android)
Note: 156/156
Folder: 46/46
Resource: 500/500
Tag: 0/0
NoteTag: 0/0
MasterKey: 0/0
Revision: 116/116
Total : 81/818
Conflits : 6
A supprimer : 0
(Conflicts are not the problem, it does not concern the notes in question.)
I can synchronize on both sides, but it doesn’t matter…
