Joplin 2.14.22 (prod, win32)
ID client : ba778a2bf24c4f34a8afd055a3135e88
Version de Synchro : 3
Version du profil : 46
Trousseau supporté : Oui
Révision : e579eb9
Backup: 1.4.0
Joplin Cloud
Sync between my PC and my Samsung A54 smartphone (Android 14) doesn't work in any directions. the Android App version is 2.14.9. I
have subscribed to a "Joplin Cloud basic" option
Make sure that sync is completed on desktop, then make sure it's completed on Android too. Any error in the log? joplinapp.org/debugging
Thank you for your tips. I created a flags.txt file in the Directory. Indeed in the Desktop configuration the target was Dropbox (I don't know why). Now I was able to synchronize my notes. Best Gianfranco Pancino
system
Closed
4
