I personally would like an entry to the 'Keyboard Shortcuts' page as a direct link as the top entry in the Help menu
Rather than Tool > Options > Keyboard Shortcuts
as I often want to quickly remind myself of one
Best would be a pop-up window that can stay visible
Doesn't need to have the ability to edit them
Although, perhaps easiest is just a link to the settings page?
Trying to help rather than picking holes
Joplin is not only by far the best note app
Its also my favourite, most useful and most used app of all I think!
Thanks always to Laurent - you are a star!
And to the others responsible
Actually, I know its mostly Laurent, but who are the others?
Or is it really a 'one-man-band'?
Joplin 2.8.8 (prod, linux)
Client ID: 289b819ae45a4a27a4567c37def14978
Profile Version: 41
Keychain Supported: No
Revision: c2a6a13
